I got a idea for one bad tiger
  • I got a idea for one bad tiger
    i got the idea to put 4 stroke briggs in their now
    got to find the clutch springs
      First of all, more power is always "cooler"... even if it is used inefficiently.
      Unsure what you mean by jack shaft... but it sounds do able. Post a couple pics of your idea and I'm sure most of us will get the just of it.
        i am refering to the shaft that has all the clutchs and brakes on it i will take some pics of the idea later
          Well I have not been here very long though I will tell you that is simething I am currently thinking of doing I just am not sure how or where to get a transmission, to make that adapter.
          MUSCATEER 6x6
          MUSCA TUR BOTA then eh?
          94 F350 4x4 7.3 IDI ZF 5sp
          Al "Camo pants"
            help
              You will be putting a lot of torque to the cone clutches as the polaris trans has a built in gear reduction. The TT trans works because of the minimal amount o torque from the 2 stroke motor. Any 4 stroke conversion will requiring beefing up the clutches and changing the jackshaft ratio.
              Acta non verba
                  wonder if
                  I found a 12 horse briggs in the back of the shop today think it would have enough power to move one of the terra tigers pretty good i dont need i lot of speed and will the clutch off the 252 fit this and where can i buy springs for this clutch to lower the engagment rpm need something to play with till i get the other one done and when i get it done something for my buddys wife and mine to ride together just need more power (torgue) than the 252
                    ok I turned the 12 horse crank to fit the 2 stroke clutch but nobody has said anything about if i can buy a spring for the clutch to make it engage at a lower rpm i was playing with the lathe and a got a few extra cranks if a cant find spring/s for the clutch i took the clutch off the engine but have not took it apart to see the spring set up was waiting to see if anybody knew of the springs i need got the engine mount built i will try to post some pics if i get time got a little more work on the crank to make it perfect(got a 1969 craftsman bench lathe and i killed the belt making some bolts for a friend before i finished my crank)but if anybody can help with the springs it would be a great help thanks i will try and keep u all updated thanks
                      tiger conversion
                      what make of clutch? salisbury?,comet?
                        i will have to look better i aint sure sorry
                          If you can't find springs; how about getting/making heavier/bigger counter-weights for your clutch. That would make it engage sooner.
                          It's all just nuts and bolts.
                            i might have to do that i am going to try and take a pic of the clutch i am sure somebody knows what it is way better than i do lol i am just trying to get something put together to last a while and have enough power for my wife who has no clue how skid steer works yet the other tiger is still on the back burner cause i think i want a max iv for me now after watching some vids of them in actionstill going to fix the tigers and will stil run the daylights out of them i will try to take pics of the clutch maybe that will help thanks
                              the clutch is the salisbury clutch i can get the model number if that helps or at least i think it is the model number lol
