New 6x6!!!
  • New 6x6!!!
    Alright well i finally got myself a new 6x6, not much yet. Its going to need some work but the price was right. I payed 450 bucks for a running scrambler and a not running attex. There pretty rough but will hopefully look a lot better when i get done with the fiberglass work, and a new paint job.
    I do have one question though. The guy put a brand new 8hp honda motor in it. It has Decent power but it really bogs down when you turn or touch the brakes when going up a hill. Do you think i need more horsepower? And if so what would you recommend.
    Thanks!
    -mike
    Switching to different tires will help a lot with the turning. I haven't ever heard of a 8 horse Honda but 8 is kinda small. I would first make sure the cvt is working right. And make sure the belt is good. A worn belt will hurt the performance greatly on any cvt style machine.
    Larry
      cvt?
      im sorry, but whats a cvt?
        CVT (Constantly Variable Transmission) is the Belt transmission that connects the Engine to the Transmission (like in snowmobiles). It keeps the engine as close to it's optimal RPMs as possible, and also acts as a clutch.
        Attex Super Chief - Sold.
          No need to be sorry.
          The constant variable transmission works with ratio's of the 2 pulleys. If the belt gets worn out it in a way gears everything up. Kind of like taking off in second gear of a car/truck. You just loss the low end power making it seem a lot weaker. At a idle or when the engine is off, the belt should ride pretty low in the engine clutch also called the drive clutch/primary clutch. It should sit real high in the secondary clutch/driven clutch. Thats the one on the trans.
          Hope it helps.
          Larry
          Last edited by LarryW; 10-19-2008, 07:17 PM. Reason: For what ever reason I started with "If".
            thanks
            alright, thanks!! i took it out today had some fun romping around in the woods behind my house. I think im going to look for a bigger motor to put on it. Any commendations? or any for sale?
            Thanks everyone
            -mike
              Im way over due for a good romping in my attex.
              For engines, if price is a issue I have been very happy with my ebay bought 16hp power max honda copy. Was under $400 new and shipped with the electric start and runs great. Few problems I have they took care of for free. Its not a briggs vanguard though but I am very happy with it. If you have the funds I would recommend the briggs vanguard series with 14-31hp. I have only had experients in the 16 and 18hp models and I love them. Just a great smooth running design. If you want a 2 stroke then maybe Don or someone else can help you there because I only really know my 340 rupp. Thats my 2 cents.
                Thanks! Im going to look around for a 14-18 HP Motor i think. I just really want an electric start, that way ill have a way to charge a battery and ill be able to do alot more.
                Thanks Everyone!
