I had the opportunity the day after Christmas to test drive the only PELEC MINI III tracked amphibious off road vehicle currently in the USA at a dealership in Philadelphia. This model is a two seater with the passenger sitting behind the driver and is powered by a Honda engine with 28 horsepower that is installed by the dealership since the standard engine is not EPA compliant. Here is my impression of it after a very brief test drive in the parking lot of a used car lot.
The Good: With the engine in the back the vehicle is relatively quiet and the steering is very responsive, it is a skid steer system with handle bars and very easy to maneuver both in the forward and reverse directions.
The body is made of steel and looks like it will take a lot of punishment going off road, unlike some plastic bodies that need a metal skid plate in order to survive.
The seats are very comfortable and the throttle is easy to operate.
The Bad: The transmission consists of a centrifugal clutch mated to a three speed car manual transmission that has to have the vehicle stopped and engine off in order to shift from gear to gear, you have to anticipate how fast you want to go in order to select the proper gear, and the selection of that gear is very challenging, the gear selector is on the floor in between your legs and there is nothing to indicate what gear you are in once you pull back on the gear lever other than when you are in reverse you get a beeping noise just like heavy trucks when they back up.
Since the engine is installed by the dealership the choke on the carbureted engine is attached to the engine and the engine cover has to be raised in order to engage it and disengage it. It should be routed to the front instrument panel but this one wasn't.
Bottom line: This model shows promise, especially since the asking price was only $13K, which for a tracked vehicle in this size range is not bad, being made in Russia probably helps. If you are within a few hours of this dealership and are interested in this model of PELEC then this is a great opportunity to check it out. My thanks to Andrew and his crew at Professionals Auto Sales for giving us the opportunity to check out the Mini III.
