This is the heavy duty trike with dual articulating rear wheels. It had a single cylinder Kohler snowmobile motor on it, not sure of the size but many of you could probably answer that. I'm assuming it was built with over the road use in mind as the headlight has a high/low beam, and I have 2 small turn-signals that came with it but I took off for hailing it back home. Didnr want anything else to fly off like the missing heavy gauge steel toolbox did at some point. Wenger back buy have no idea where it came loose st, but it sported 2 of these tool boxes. I may need to get a pic of the ID plate on the frame if I don't have a clear one in my gallery, but I'm about 91.73% sure it is s blank BGW Ind. Placard. Has electric start and this Apex gearbox I cannot find anything about either... model T-1101, S/N 07745. So an info on those would be awesome, like where does the shifter arm hook on to it st, etc...
Well, that's all I can remember about it, and am stuck on restoration of it till I get some more info about it. Hopefully the pics will post. Let me know if not...
Scott
Scott
