just bought a old scrambler , w/ the briggs in it .. the whole thing is in damn nice shape , runs great and looks decent , tires are good .. just turns to the right , and not real well to the left .... any ideas ??? thanks chuck
I too Recently just bought a 1964 scrambler. I can't say mine is nice shape but when im done with it it will be!! Do you have the steering wheel or the sticks???
if the unit has a steering wheel you will likely have to shim the brake pad plate
closer to the clutch disc on the left side. E-clips are used for shims.
If you have laterals (sticks) to steer with the hydraulic fluid may be low and leaking on the left side.
i use type f trans fluid,,,,Seems to work very well, summer/winter
Try making sure the resevoir is full, bleed the left side, like you would bleed car brakes.. slowly.... a little at a time....
