i tried putting chains on my scrambler i just bought a few weeks ago and im lost. there were no chains on it when i bought it. so how do i tighten them up and all that becaause i dont see how it all works.
help me scrambler owners
Scrambler chains...
Hi
Adjust the first set of chains from the clutch brake disks,4 bolts, loosen on jack shaft.the easily tighten down the two long bolts to get decent tension..not too tight though, loosen the 4 long bolts on the cross member on top,,,,AND the 2 bolts between the 4 long bolts ,1/2" wrench (2 of them)
Slowly tighten the 4 long boltsuntil a decent, not too tight, tension is on the 4 chains that run the back and middle axles. Tighten the 2 1/2" bolts up. Thennnnnnn slide the adjusters for front chains, up. until front chains are tight too.. then u r done? run the machine around a little, the go back and readjust the chains,,
Bemarv
I just searched for a scrambler on our site there were a few pic's of the chain adjusters one looks like a max in line adjuster and the other for the trans was a sprocket type like on an attex so just go to gallery then search for scrambler pic's post some pic's as you go so we can see and help you if you need it.... let us know how it's going ......
oh I see amphiman1 has chimed in he know alot about most aatv's so your in good hands..let us know how your doing....
