Does anyone have photo that shows what fluid reservoir looks like and is located on the model 1200 scrambler? I am missing mine and have no clue what to look for or use in its place. Any ideas?
I also just put on new ignition key switch and this is how I wired it. Is it correct?
Starter switch:
B (red wire to battery or Coil)
S (black wire to middle post on coil) between two larger wired (bat and ground) Starter??
A (white wire to alum fin looking thing)? alt?
I have 2 more post on ignition switched one marked R and the other looks like I? No idea what goes on these if anything.
I also have one green wire which is with other wires above and goes to back of machine but neither end is hooked up and I have no clue what this is for.
It almost cranked over and did run for very short time on starting fluid but since sitting up for 3 years after motor rebuilt I guess carb now needs to be cleaned. I bought some B-12 liquid carb cleaner. Would it be best to take carb off and just let it soak in the B12 or just add it to gas and let it run little each time until it gets cleaned.
Thanks for any help as this looks like it would be fun when I get it going.
Ronnie
Starter switch:
Ronnie
