I have found a prairie Bobcat for sale.  Add says $600 it runs and drives but needs a little work.  Would this be hard to find parts for?  This could be a headache if i want to run it.  Although on a long term project it might turn out to be a bit of a collector?  What are some of your thoughts?
Prairie bobcat Are they rare?
 If I saw that and had $600, I would jump on it.Originally posted by Maniac View PostI have found a prairie Bobcat for sale. Add says $600 it runs and drives but needs a little work. Would this be hard to find parts for? This could be a headache if i want to run it. Although on a long term project it might turn out to be a bit of a collector? What are some of your thoughts?
 Most parts can be made at local machine shops. Other parts maybe not so easy but thats when you rely on others on the site to help you out.
 Hope that helps.
 Prairie Bobcat
 In the early 1990's I owned a Prairie Bobcat and found most of the parts to be generic in nature. I don't see a need to buy parts that cannot be bought at your local bearing supplier or manufactured by a good machinist. They were a neat 6 wheeler and very fast.
 I didn't get the Prairie Bobcat, I have a couple of garden tractor projects (1969 Bolen & 1974 IHC cub cadet looking for parts or attachments) and the 1984 6x6 Argo on the go. I figured the $600 would get a long ways on a couple of these.
 Beeman FYI the Bobcat is advertised online on KIJIJI around Calgary somewhere.
 ManiacWhats a little gas to save a few steps!
 I picked up that bobcat (in a round about way.. no need to explain)... it has a rather large whole in the back, dude gave me the fiberglass piece which had the hitch attached (wonder how it ripped apart? hmmm...)
 Oh well, since I can't build/repair yet, I may as well collect.
 Hello every prairie bobcat operators new bearing idea show on channel in spring works
  Yes princess auto is about the best place for parts, Yes princess auto is about the best place for parts, But i found a way better system for bearings But i found a way better system for bearings no more none greasable bearings a little later in spring I`ll show all the p.b.c. Operators a new bearing system to much snow now no more none greasable bearings a little later in spring I`ll show all the p.b.c. Operators a new bearing system to much snow now    . .
