Terra Tiger
  • Terra Tiger
    Dose anybody have any idea on how to get axcel out of a terra tiger It has been setting out side for 20 years the pins that hold it in place are rusted I have tried wd 40 pbr hammer and punch I need some help here thanks scottielee
    terra tiger....
    I'll bet it is one of the old style too with a tapered pin in it too....
    wash out the tub really well,no grease/oil etc . Heat up the sprocket, not the pin too much, find the smaller side of the pin. A vice grips, a proper size drift pin and a heavy hammer , go for it!!
    Those pins were in there very tightly from the factory too.... been there, done that.......
    Did any of them come out at all?
      Use a 5/16" pin punch to start. Have outer axle brg housing bolted in place! and you can support outer axle on blocks as well so its solid when you driving on the pin!As Amphiman1said Heat sprocket up around middle! We place a strip of steel under sprocket and wet down body. Another tick that works after you have sprocket hot! is to melt a candle into pin. Be careful it sometimes flames up! The Wax penetrates into it. If that doesn't work you can try drilling pin out, Or get plasma cutter and cut axle on inside of sprocket and remove outer brig. housing (slide outward) and cut the outside of axle Then you can get sprocket in vise press or drill press to remove pin? Hopefully a little heat and wax will work! I haven't had to cut any out myself. But know of some that did. Good luck. Hopefully its not front one
        Terra Tiger
        Thank you guys so much for the info I am gonna try it to night will let you know how it worked Thanks Scott H
          terra tigerrrrr
          Or drill them out......... carbide drills
