year,engine hp (model sbh-223 serial 8365 bottom right of tag is 08403,tecumseh i think)under dash sticker says model 1200. are air scoops on fenders stock? they have 3" hose running back to motor.also are the rotors suposed to be glued together,after the clutch disengages it only pulls the first rotor disk into the pad
scrambler info
Hey srg121,
Wow a scrambler
The hood scoops arent original that I have ever seen. The drive/brake rotor sounds normal. I did a search and did find this on your engine.
Parts and Diagrams for Tecumseh SBH-SBH-223
Reading the last link sounds like it could of been a replacement short block? It is for 2 cycle engines but has Identiification tag info.
I believe they came with a 7 or 8hp briggs
10 or 16 tecumseh.
I guess 12hp too but cant find it in any brochures.
Good luck with it!!!
