scrambler brake thickness
  • scrambler brake thickness
    what is the thickness of scrambler brake pads
    I checked the pile of extra's I have and the thickest I found was .150". That was on a pad that the entire surface wasnt being used and that should be the brand new size as the rotor never touched it. I also measure the clutch pads and the thickest was also .150". Not sure if if varies from model to model as I do know the clutch pad shape does.
    Hope that helps.
      brake thickness
      thanks once again larry
