I have ripped my terra tiger down to the shell and plan a full restoration. The only thing left to do is pull the top off of it. Are there any tricks? Also, when I go to put it back on, what compound is recommended for bonding the two pieces (top and bottom) together?
Thanks in advance for any "tricks of the trade" you might have to offer.
After drilling out all rivets and removing them and molding, we use heavy thin knife and work all around body seams to loosen it. If no one used fiberglass on it. We just use silicone sealer when putting them back together. If you fiberglassed or sprayed gel coat on it, you would have to cut body apart If you or next person ever needed to remove it again.
