There are two metal skid plates on the front of the terra tigers. What is the best way to bond these to the fiberglass? I imagine they take a beating so bolting them through the fiberglass is probably not a good idea.
Sorry for all the questions and thanks for the help so far. I promise that once I get these dialed in, I will provide a wealth of information and tips. But for now, I am still in the learning phase.
epoxy would work, or 2 bigger nuts/bolts/washers.on each, with screw driver slots, so the heads of bolts don't hang u up on something,,,, rocks, tree roots etc
So Im assuming these are just a custom skid plate. If the metal is thick enough, how about tapping the plates out and using a proper length bolt with large washer on inside? Maybe even strips of metal in inside going across to the other bolt? That way no dragging heads on bottom.
