Scrambler primary drive belt
  • Scrambler primary drive belt
    I just purchased a scrambler 1500 at a swap meet. It has a kohler k361 in it whick runs but needs carb rebuilt. The drive belt is old and worn. This looks like a huge process to get a new one on - I can obviously cut the old one off. How do I do this or where can I find the information. Rhe scramble has some other minor issues too bu t 1 problem at a time - Any place to buy K361 parts - those are hard to find too. Thanks
    belts are a pretty big job, mostly just time
    when you do put one on, put a second one on so you have a spare
    whats wrong with the carb? dirty? broken gasket?
      You may want to reach out to Amphiman 1 or Larry W. they both know their Scramblers as well as many other AATV's. I don't think the process of changing the belt is as bad as it looks though, just a matter of doing it in the right order. If all else fails, you can get a copy of the service manual from RichardsRelics.com.
        ^what he said^
          ^what he said, he said minus the richardrelics thing^
          Its really not that hard like may be an hour tops. I put the new belt on the Gotcha in like 1/2hr.
          What parts are you looking for on the k361? That is the overhead valve one right? I know where a k361 overhead valve motor is with a bad head. I can talk to him maybe see what he is doing with it.
            If you search the threads in this forum, amphiman1 gave mikeylikesit5808 directions on how to replace the belt on a scrambler. Just search "scrambler belt" and it should come up or look for posts from mikeylikesit5808. Hope it helps.
              belt me
              Yes, it's here somewhere.. 6-8 bolts, 1 bracket, if your model has one
                thank you - i will search on the drive belt. As with anything getting old bolts can be a challenge plus the right order too.. As far as the k361 GOES-carb leaking gas out of the bowl reain (gasket) plus hard to get the engine to a low idle where drive belt is not engaging - i THOUGHT maybe the idle circuit - It is the OHV Kohler. Could be valves too. I hate to tear into it unless I know where to get parts- It does run. Hard to start - thought points or something of that nature. Sure would like a reverse. Left clutch or cylinder need to open a little further - the cylinder was leaking but I tightened up a fitting and the leak stopped. Maybe need to bleed it better. I do not know much about these 6X6 but learning fast and having fun too, It is a blast to drive if I can get everything working properly - thankyou all for your input
                  primary drive scrambler 1500
                  I hate to sound thick but i still cannot see how to get the belt off - actually go on. It looks like the left clutch/brake has to come off and the shaft has to slide out - The frame that holds all this also has the engine too. I do see how all the chains adjust - any pics or digrams out there?
                    I made this diagram to help.
