I keep throwing the 2 chains off of primary sprocket cluster(2 sprockets). The teeth on these sprockets look pretty worn. Any help would be greatly appreciated. It has the 16 hp techumseh.
scrambler throwing chains
Originally posted by g-man View PostI keep throwing the 2 chains off of primary sprocket cluster(2 sprockets). The teeth on these sprockets look pretty worn. Any help would be greatly appreciated. It has the 16 hp techumseh.
Here this should help with the adjustment locations.
The chain to the center wheel was a little loose but the chain to the rear wheel was the first to come off. Everything else works good. I hope I can adjust this problem out. What about a bent rear axle shaft or a worn axle hole ? Could this cause the problem ?
Originally posted by g-man View PostThe chain to the center wheel was a little loose but the chain to the rear wheel was the first to come off. Everything else works good. I hope I can adjust this problem out. What about a bent rear axle shaft or a worn axle hole ? Could this cause the problem ?
By axle hole I meant bearing/bearing mount bolt holes.http://www.6x6world.com/forums/image...s/dontknow.gif Thank you for your help. I hope to work on it this weekend.
I just replaced a couple of the chains on my recent purchase and had the same problem. Check that the side plates of the rear chains are not hitting the inside hub of the spocket on the three gear cluster. The hub is slightly larger on the inside of the outer spocket than on the outside. When I compared the chains the side plates on the new one are slightly taller than the old chains and thus riding on the hub which kicks the chain sideways. I simply used a die grinder to cut a slight grove in the hub to accomodate the side plates.
