Another amphicat question
  • Another amphicat question
    Hi everyone me again. Its about the exhaust for an amphicat i believe that on the early models the exaust exited on the right hand side of the cat and the late models on the left.
    Can the standard exhaust be fitted in either side or has it got to be specific to each side.
    Hope that makes some sort of sense.
    Many Thanks
    Peter
    HI FLYINGPIG,
    I have 3 amphicat bodies. 1 early b7 beehoo, and 2 later bodies. all 3 exhaust exit on the right. You can exit it anywhere you want, as long as it's above the water line. The other thing is that you will need to make sure you insulate the abs body from the exhaust pipe with a non-flamable material such as asbestos. I think an automotive exhaust donut modified to the correct size should work.
