What is the bolt pattern for the Scrambler "GOTCHA" with 4 bolts?
Gotcha 4 Bolt rims???
Thanks Larry I think I will call up some of the local golf courses and see if they have any, or maybe they can point me in the right direction.Originally posted by LarryW View PostThey should be 4 bolt 4" circle. If you need new ones make sure you get some with the little lip to hold on the bead. Most rims do but some dont. Most golf cart style will work and that is what I run on my attex.
No problem. I only run them because there cheap. Some people have problems with them coming of the bead at low psi but I only had that happen once and that was with a log jamming it off. I went to the garage to get air and the bead was back on(seated).
Strange I know but I have buckhntr17 as my witness, lol.
Another thing to look for is the rim width. I would get the skinner ones to help keep the bead on and to also make the tire a tad taller. I think mine are 7". I have both, I will measure tomorrow if I remember after work.
