1973 Gotcha Build
  • #16
    So I tried again to remove the hubs today
    Snapped another Monkey wrench.
    Then I made a slit in them and heated them up and soaked them with more PB BLaster
    I only made the slit on one side. Wondering if I should put a slit on the opposite side of the hub?
    • #17
      I'd give it a bit of a beating. Put it on an anvil and flog it with a hammer while turning it around.
      • #18
        I finally gave up on the Scrambler hubs and took them to a machine shop to be pressed off. Cost? Priceless.
        • #19
          So you took the whole thing to a machine shop? Or Is there a way to get the axles out with the hub on?
          • #20
            Looks awsome, I amgetting one here shortly and was wondering on the actual size. Could you possibly get a picture with a full size man by it. Im 6' and about 275 pounds and am wondering how welll i'm going to fit.
            **Also,those are piewrenhes. Monky Wrench's have a qooden hande and have a flat spot on the back ofthe jaws that can be used like a hammer. Im only saying this because I larned it like a few days ago in my Automotive Tech class.
            • #21
              Im6'6" and about 275 and plan to run a single seat in this Gotcha. Im not sure how well I would fit in the stock bench seat set up though.
              • #22
                Alright thanks. I found a video on here and it's bigger than I originally thought it was.
                • #23
                  1 down 3 to go.
                  lots of heat and I beat the snot out of it.
                  • #24
                    More work done today.
                    1 more axle pulled and almost every thing from inside the tub.
                    Im trying to keep my parts organized
                    • #25
                      That is always a good place to get to, when there isnt much left that you can remove from the ATV.
                      • #26
                        Now I have nothing left to remove.
                        I will start the fibergall work within the next week.
                        • #27
                          looking good, keep up the good work
                          Kevin Hough
                          TREBMASTER
                          (____>
                          .OOO
                          • #28
                            So I was back at it today.
                            I finished the fiberglass patch work and did some of the body filler today too.
                            Im sick of sanding
                            Dont be too hard on me im not a autobody guy.
                            • #29
                              Sorry I have not been on in while, Im still working on the Gotcha.
                              I have been side tracked by another project of mine (the jeep). I will
                              keep working on this and get some updated pics soon.
                              • #30
                                what kind of lines are you using for hydrolic lines? I have to replace mine and I am not sure what to use
