Got a main chain that's in bad repair. The 35 triple. When installed and adjusted it appears loose. The chain has 4 master links installed. I've counted 145 pitch's, the chain laid flat measure's approx. 55 inches. Has the triple stretched or maybe links where added? Any insight would be appreciated.
Kid "N" chains
well I dont exactly understand what your saying but one good thing to try is take the other triple chain off and compare the lengths of the two chains maybe the loose one is too long...like you said or maybe something else If they are the same length then when you reinstall them and it is the same I have all the manuals I can (If i can figure out how) email you the parts of the manual you need.
8x8 twice as good as 4x4
Thanks for the support. What I found is that both chains are the same length. Good thing I got to looking, I didn't realize that the triple has the extra master links for a reason. I think the chains are simply streached. The question of the day now is. Will the main chain remain loose or taunt, regardless the adjustment of the jack screw? Meaning is the tensioner sprocket the only adjustment available?
