Mike ask me to start a new thread so here goes guys I think I have Pics of every stage of construction and even diagrams of the drive train.
When I decieded to build this vehicle I essentially wanted an 8 wheel drive boat that was not nose heavy ( engine in front) and have no fears in the water or braking on down hills would carry 4 people and all the camping gear (good payload) and I could fish from all day long and not worry about a windy day on the lake. Oh yea I did not want to depend on the tires for propulsion on the lake. I wanted a vehicle to drive across a lake for miles drive up on the shore and camp or 8x for some more miles to camp or hunt.
This is what I have come up with, having built several sand rails I had formed 4 c channels 10 feet long 5 inches tall from 10 ga. steel to form the lower frame for axle bearings. On top of this I made a 2" tube frame .095 wall thickness with all the diagonal cross bracing. Then I bought 3 sheets 5x10 feet of .092 aluminum had them bent to my specifications then welded for 8 hrs with a spool gun. When I put the frame in the alum tub I had to push it down with a fork lift with 500 lbs on the forks good tight fit.
Its 13.6 feet long and 72" wide the bottom section is 48" wide with 11" fenders each side. The entire edge is caped with 3/4 alumin. conduit. I have a sand rail 11 gal. spun alum. gas tank. The seats move on a rail and clamp down to where its comfortable and will lay flat also. The cushings I will have sowed will attach with velcrow so they can be removed to go under sleeping bags. there is also a roof rack for the lighter things like sleeping bags tent chairs etc. Eventually I will build an amphib. trailer also to pull.
