Chris, thanks for response.... Max rpm is 3600, it is a 4 stroke 2 cylinder engine. It has 1" horz shaft. I have found the calculators for speed, size of tires, hyd flow, etc. I guess I could go for many different torques and setups of hyd motor sizes but I am asking for advice from you experienced guys on recommendations of pump/motor (hyd) sizes. Tires are 22" in dia, not sure of sprocket size but I think they are app 4" in dia. I know the hyd pumps displace small amounts and are kinda priced accordingly. I am thinking around .67 cu in displacement. Also, if anyone has expert knowledge of what type of hydraulics are in some of the better lawn mowers like golf courses use that I may salvage pumps/motors off of. I found new home type rider mowers with zero turn have little hydraulic/pump-motor combos that are independent and belt driven. So a belt drives two different hydraulic units. I don't want to use belts if I can get away from that. Thanks in advance for any advice you guys can give. I will keep build photos updated on this forum for all to see...
Caveman
Caveman
