could someone guide me as is the distribution of the hydraulic hoses to such master cylinder which cylinder back thanks is with the wheel of direcion
scrambler Hydraulic hose
Right side steering cylinder side to right side actuator front. Left side steering cylinder side to left side actuator. Brake master side to right brake (rear of trans). Right brake cross over to left brake. steering cylinders and brake master top connection get teed together and go to plastic reservoir. The reservoir is not critical as the all the master cylinders have a small reservoir built in. the system should be pressure bled from the trans to the master cylinders. use a small grease pump filled with transmission fluid.Acta non verba
