I got my new lines on but whats the best way to fill it back up with atf?
Gotcha hydrolic question
Buy a cheap new grease gun-remove the rod and spring that pushes the grease up-silicone the hole that the rod was in-Once silicone is dry fill the grease gun up with atf then holding the grease gun upside down attach it to the bleeder fittings on the brake and clutch fittings-pump the atf through the fittings and then chek your hydraulics.Do a search for scrambler hydraulics and bleeders and it will explain.
