My buddy found an old Amphicat in a shed of his now past away uncle. The motor is loose and it isnt all rusted. It it worth fixing up and will they handle tracks. It appears to be in fair shape.
Found an Amphicat
Well, the 3/4 inch axels and Roller 40 chain are pretty weak, but if you can get a set of 6x6 Argo Standard 13" wide plastic tracks, it should handle them no problem, as long as you have the proper sized tires on it (they'd have to be 20-11-8) so the tracks don't rub on the body, but again, they are build pretty light, and the old ABS bodys are usually REALY weak, but the all depends on it's condition now. Nice find though!sigpic
Originally posted by ndcommander View PostMy buddy found an old Amphicat in a shed of his now past away uncle. The motor is loose and it isnt all rusted. It it worth fixing up and will they handle tracks. It appears to be in fair shape.
I would say try to get the engine running for a few bucks, then test the tranny, and if all is good rebuild it. If the engine can't be fixed, the tranny can't be tested properly, sell it to someone that needs parts. Keep in mind, if it needs new shoes all around, 6 tires will add up real quick.l like to buy stuff and no I don't do payments!
Hey Drew, Have you ever experminted trying to make an Amphicat style track? I've got an old argo that you can't put spacers on, so no rubber tracks for me, but I was wondering, how does the Amphicat "soft track" style track work? They any good in mud? I'd look at making a set of these for my argo.Last edited by 1975 Argo 8x8 2-Stroker; 07-17-2011, 09:52 AM. Reason: Had to "re word" it or I run the chance of sounding like a moron... lolsigpic
I have not played.with the Amphicat tracksmyself. i have only seen them on one of amphiman1's machines. if you can find conveyor belt cheap, they are probably worth making. your psi will be lower on the ground, but there is no tread on the tracksl like to buy stuff and no I don't do payments!
