Hoot aatv
  • Hoot aatv
    Has anyone seen or tried the Hoot AATV?
    Is it possible that you are referring to a Coot? Coots are 4 wheel with articulating front and rear half's. If so I did see a website that is re manufacturing it. I believe it is being made in Africa.
    Mike
      hoot
      I saw one at a dealership in new hampshire last year , I did not see it go but it looked like a lot of fun to try out it carried two people and the seat had a shock in it to give it a somewhat smooth ride.
        Here's the Promo Video for the Hoot, from Knox Outdoor Products.
          Looks like all is not well in Hootville
            That just seems like a financial squabble with owners, investors, and management that took place in 2003 and early 2004 when Hoot was first being manufactured. I think the company itself is still in good standing.
            Although it was interesting to read that they didn't sell ANY Hoots for the first 6 months of manufacturing but continued to manufacture them anyway.
              Yeah Mike i should have said all was not well in hootville. It does make for interesting reading though.
                check it out hoot etv
                hoot etv 6x6 new
                  I tried a hoot at a new hampshire deeler a few years ago. I think when they first came out. I didn't like it at all. seemed very top heavy and very cheap.
                    Bw6,
                    Ray seeing as you know the hoot I have a question about the lack of frame. Is it durable enough with just the fiberglass body?
                    It seems to me any Machine that is bulit with fiberglass = body repair.
                    However that is on older machines I don't know how far fiberglass has come in 20 years
                    Mike
                      Good to see more selection out there but..
                      I inquired about the Hoot ETV some time ago via email because the dealer in Ontario from the Hoot website did not give any other contact details. It took a long time for any one to get back to me so I was not sure on there business operating status. I liked the fact that it fit into pickup truck but was not happy with it only seating one person. I figured if the price was right I would just get two machines or more. This puts me back to towing a trailer so unless this one has a price advantage over the Argos and Maxes I would stick with them. I was quoted approximately $10995 CND with snow tracks option plus taxes and delivery. Less then the Argos and Maxes I was quoted on but not by much, plus I can get an Argo or possible a Max used. I recently cam across the thread saying the Max II can fit in a full size truck too. This I got to see for myself for some reason when I measured one up at a boat show I determined it would need to go on a trailer.
                        Vacuum Infusion Process
                        Hi MicMac, All the Hoot fiberglass components use the "vacuum infusion process". You can Google it for a more detailed explanation, but basically all the excess resins are vacuumed out of the glass laminates, which increases the fiber to resin ratio, which equals high strength/low weight. Part of the initial testing process was to select random samples of the body, and send them away for stress, tensile and yield analysis. The results were excellent, stronger than most aluminum and close to low carbon steel. Where is did beat them all was in yield, meaning it could take a tremendous impact and rebound to original with no deformation.
                        The other part of the strength equation is design, by using boxed beams, cloth orientation, and composite materials in high stress areas we ended up with a light strong body. It has also proven out in testing, and customer use to be extremely robust and is warranted as such.
                        In fact for the entire testing process a few people had the job of trying to break the machine by extreme riding. We hired a few people (one ex. marine) whose jobs were to break it. And break it they did. So we would examine the failure, redesign or replace it and send it out again. After a year of this we decided the machine was ready for market. Hence the name Hoot ETV (Extreme Terrain Vehicle)
                          Sorry Robio
                          That was me who gave you the quote, sorry for the confusion and delay. There was a broken link on the Hoot website and I did not get your inquiry for quite a while. Also due to the value of the Canadian dollar, we have passed on a $500 price reduction.
                          Regarding whether the Max II will fit on a pickup truck. The problem with all the Argo's and Max's is the width. To go between the wheel wells the overall width needs to less than 50". Both the Argo and Max are much wider requiring you build some type of ramp. Only the Hoot ETV will fit. Length is not a problem for Argo/Max/Hoot, with a short box you just put down the tail gate.
                            Thank you for getting back to me any how.
                            Sorry your web site had those issues but I will let other know about your machine.
                            The tracks you guys have would they work on an Argo? If so let me know the price and width of track. They look like a better track system.
                            P.S. the Argo 8x8 is 5' (60") wide I could not image that fitting in any pickup safely or conveniently
                              Hoot ETV Tracks
                              Robio, the Hoot tracks are designed specifically for it. They will not fit on an Argo or Max. The Hoot tracks are 12" wide, use an offset rim, add 5" to the width of the machine (55" wide), that makes them 2" narrower than an Argo without tracks! The psi on the ground is an extremely low .4 They are made of plastic and will have a rubber cleat attachment shortly.
                              Thanks though for trying to drum up some sales, appreciated.
