I got the other seals in and the second hydro bolted back on. Then discovered that the control rods were installed wrong when the machine came, they were bolted to the top of the attachment plate but when installed correctly, they hit the intake, and also the throttle brackets, where all the linkages attach to the engine, governor, etc, etc.... things do get better though, because all those problems will go away after I rework the driveshaft, which is somehow crooked? bent? off center? at the u-joint. Not a big deal except for the fact that this causes a wobble that is strong enough to move the engine when the starter is engaged. Which will prematurely wear out the transmission. ain't life great!
So, now I get to re-re-re-re-re-revise the driveshaft. Thing is this would be no trouble at all if the engine were a straight shaft instead of the tapered shaft that it is. VERY open to any of the following: suggestions, trades, reasonable offers...
I haven't mentioned the impossible to reach bolt locations Nick, there is no way this is a one person project. I could reach every bolt on the hustler 950 with, at most, a long extension, but this thing, no way can I even think about reaching both the bolt and nut on most of them by myself. I promised my Mom I would take her for a ride in it as soon as it's finished. She is well past 70 and I would like to take that drive asap, because at that age anything can go wrong. So it goes way beyond just wanting to hunt out of it!
, so when I assumed it was and just started turning it for the driveshaft I cut the thing .028 out of center. I have since gotten a jewelers lathe from my dad that would grab the center bore of the hub and got it cut concentric. I also cut about 1.5" off the end of the crank and drilled and re-threaded it, that will shorten things up some and should give me a little leeway for the length of the driveshaft. There is a fine line between too short and the control rods hitting things still, and too long and having the engine against my knees. Tomorrow I hope to start the work on the shaft and u-joints.
