My new project Sierra T-Boss
  • My new project Sierra T-Boss
    Just picked it up for $300....need love...but it's what we do....lol
    A person who says "anything is possible" obviously has never tried to staple jello to a tree....
    I got some pics of the running gear....I've researched the unit and it's supposed to have 2 trannys right? Mine has one...everything looks like it works as it should....I read that these go forward and reverse when you move the sticks....mine has a shifter to do forward and reverse..and the sticks are on the right instead of left....anybody have any expert opinions on what I got? I hope it's not "frakenstiened" together....lol
      looks like a nice machine
        Yup, Thats a T-20 shoved in there not the original tranny. If it works, you are probably better off, but it looks kind of cobbed together. I don't like the extension on the input shaft, but at least it is braced. I would redo everything and center the t-20 so the machine is better balanced as well as getting rid of that crazy extension. The good news is you got everything there to work with and the parts for the t-20 are available and still produced.
          Thanks Drew...that makes me feel a lot better...lol...I should of done more research on it....but then I probably wouldn't of gotten it. After reading your post I looked at it again and it looks well engineered..the shaft is supported on both sides and they are greasable, there are adjustment assemblies for the chains, again well engineered....when it's running, it goes forward without touching the sticks, just give it throttle you pull them back to turn or stop, when you go in reverse you pull the sticks back to make it move...I guess it's working right. It's got a 10 horse single Briggs in it that moves it, but I have a 440cc twin cylinder 2 stroke Kawasaki out of an Arctic Cat snowmobile that I think will move it better...lol...you guys think it's worth the time/money to put it all together?
            Well I decided to tear it down and start the whole process...the more I look over the re-engineering that was done the more I'm thinking "leave well enough alone"....it all works, it's tight, and has slack adjusters and everything....it was definitly well thought out....so I think a clean up of the chassis and check everything, the T-20 probably needs to be gone thru I'm sure...and once the chassis is out I can mount the 440 Kawasaki engine and make an "engine tray" with rubber isolators and adjustment slots for the belt....fix all the small defects in the tub, rewire it and last but not least the tires...lol...should be a wicked ride with a 38hp 2 stroker powering it...
              I think you need to replace the exhaust system.
              Was the previous owner in the plumbing business?
                Yea you gotta love redneck engineering...lol...the chassis re-engineering looks like someone really took the time to build it right...the guy I bought it from was the "slap it together and ride" kinda guy, hence the 10 horse briggs (which I got running and runs pretty good) but didn't take into account that the briggs has a 3600 rpm limit, only 10hp and has a different power curve (speaking on clutches)...which is definitly not enough for the machine to be all it can be....I'm transplanting an Arctic Cat snowmobile engine in it (440 Kaw twin) supposed to be 43hp from what I've read, it has a Makuni carb on it so the transplant should be fairly straight forward...I've gotten ideas from a few examples on here for an adjustable engine plate with rubber isolators...I'm pulling the chassis to clean everything up, get an idea of how all the added chain adjusters work and the ease of fitting the engine onto the chassis. I'm thinking of going with a hand throttle on it too, I liked it on my old Attex and it would be easy to do....the main reason I think whoever did the rework on the chassis did it that way was because the latterals would of had to be centered or close to center and the machine has "bucket seats" molded into the body...so centering the trans would put the contol levers in an awkward position.
                  You may want to check the driven end CVT as the cam side usually faces the T-20. They may have installed a reverse spring in it to get it to work. If you plan to put the sled engine in you will want to have a proper CVT setup.
                  Acta non verba
                    Gotcha....I'm assuming because the briggs engine and the Kaw both rotate clockwise looking at the pull starter side they would be the "same" so to speak, the machine had the stock engine in it when the previous owner got it, but it was siezed...so he swapped in the Briggs engine...my guess is he probably used the clutch from the original engine...the Kaw has a clutch on it already and I'm hoping I can use it without swapping it out. When the time comes to fab eveything in I'm gonna be asking a ton of questions to make sure its done right...I'm not one to half a$$ anything together...that causes more problems then it's worth...lol. I'm going for the "rider/driver" thing rather than a full resto....I just want something decent to have fun with...lol
                      The more I look at this thing I keep wondering if the whole chassis/running gear wasn't swapped from another machine...is that possible?
                        I think its a custom.
                        Use the clutch that is on the kawi engine. If the drivetrain setup works i would leave it as it is.
                          I plan on it....I don't think I could do any better...lol. I did start on getting the Kawi started...got spark on one cylinder, not the other so I gotta work on that....the engine is also set up for electric starter option and has a Makuni carb on it, which is really cool. The cooling fan has a few blades missing...but I got 2 others to scavenge parts from! I hope to have it fired up by tomorrow, once I get the machine torn down it should come together nicely and have plenty of power, all the axles and bearings feel tight, I'm gonna pick up a plastic welder from Harbor Freight to repair a few defects in the body (being poly that should be easy)....the biggest expense is gonna be tires at $65 a piece.
                            Custom build with T-20 trans questions
                            Here is a link to a vid of the way the T-20 is set up in my Trail Boss (the vid is kinda choppy, I don't know why)...both fixed sides of the clutches are on the same side and I'm just wondering if anybody has seen anything set up to run this way...
                            Sierra Trail Boss :: seirraTBvid1.mp4 video by Bigsalpics - Photobucket
                            Thanks...big Sal
                              I dont like the slop and I am confused about the double 40 chain. The t 20 has 50 chain from both sides so whats the extra stuff on the crazy long input shaft. Btw, I believe the po put the extension on so he could sit to the side and still have the engine offset the weight, but if you would center both and align them correctly you could bend your sticks off to the side and be better built and more stable.
