I recently bought a Sierra Trail Boss that needs a wheel bearing. Does anybody have a part number for that? Also, is it set up like an older Attex bearing system or not as simple? The bearing is so bad that there is an inch of play, so I'd assume I need a seal too?
Also, it has a Kohler 300cc engine, and has a hard time doing a 360 even on grass, and it's not due to the trannys. Should I have more psi in the center tires? What PSI should be run in the others? Thanks for your help!
