4 Stroke engine mount plate for attex
  • #16
    Originally posted by rickga View Post
    You guys are hilarious! Really need to make a Pine Lake ride and get the full experience
    If I still have the coot, you are welcome to ram anything of Tom's with it. Coots don't care
    • #17
      Originally posted by jerseybigfoot View Post
      Your other option is to install a performance clone single which fits easily under the original cover. Smaller,lighter more horsepower and better useable rev range.
      Ok and who sells or makes these??
      • #18
        Hey Dave, if you get it as close as race did you can just heat and reform the engine cover to fit. Put a piece if 5/8 plywood the same shape as the air cleaner lid on top of the air cleaner, close the engine cover, heat it up above the wood with a heat gun,to push down on the engine cover to get it shaped. I used some weight to hold it until it cooled. Way better than hacking apart the engine cover.
        • #19
          Thanks Joe! I really don't want to cut up this cover so I may try it on an older one and see if I can manage it without totally destroying the darn thing!!
          Thanks again!
          • #20
            The unistrut will hold up just fine to 20+hp. One of the attexs has a harbor freight 22hp and no issues.
            • #21
              this a 4 chain setup your running like mine?
              Thanks
              • #22
                Yes all 3 attexs are 4 chains setups.
                • #23
                  Bullfrog Motorsport, Vegas carts.
                  Bullfrog can build one with a charging system and electric start.
                  Acta non verba
                  • #24
                    The first one I made with just scraps laying around.
                    • #25
                      Thanks for all your inpuy on this! I've got to get busy and get this project going...
                      Dave Phelps
