Multiplaz. Welding, Cutting, Soldering, Brazing... does anyone own one of these or uses one at work what do you all think of this tool I just discovered it on the net reading about aluminum welding.
has anyone used one of these
i done alot of welding .never heard of this .Unless it is tig or even mig welded i be leary of it long ago i did some with a stick welder but alas i cant remember what it details or how i did it. I have seen something like this at a show i was at he welded a motor case a pop can and a prop it looked pretty good but alas i rather go a route i know will work .Just my two cents
Not Bad! Still would prefer to see it in action in person. Maybe even test drive it, so to speak! LOL!Originally posted by azz7772 View Postit says it can cut up to 3/8 '' thick regular steel and it can weld up to 2'' regular steel it can also cut ceramic tiles, quartz glass, bricks,and concrete,plus it can weld aluminum,and copper as well.Road?
What road? I blaze my own trail!!!
agreed. As a welder myself, I would be wanting to use the machine before I would buy it. Any salesman from miller or lincoln would let you do this, this guy should as well. Still, hard to beat time proven methodsOriginally posted by Frymechanic View PostNot Bad! Still would prefer to see it in action in person. Maybe even test drive it, so to speak! LOL!
What I question is with water plasma, what creates the pressure for cutting? And with the same plasma control it enough to weld and not blow through? The video on welding wasn't very clear.Originally posted by clevernickname View Postagreed. As a welder myself, I would be wanting to use the machine before I would buy it. Any salesman from miller or lincoln would let you do this, this guy should as well. Still, hard to beat time proven methodsRoad?
