Ok, I'm usually pretty good with small engines but this one has me stumped so I turn to my friends here at 6x6 world.
Background:
A few weeks ago, I picked up a Bobcat 610 skid steer loader. Wisconsin V4HD engine (4 cylinder gas engine with a carb and distributor). Previous owner thought it "was blowing up, cause it smokes real bad" looking it over at his place, I noticed that the choke was stuck fully closed and the smoke was black and smelled of fuel so I went ahead with the trade.
Problem: Once I freed the choke, she fired up and ran great (tons of power) for about 15 minutes, then it would sputter and die. It would refire, but with a miss and no power. If I let it cool for 15 min, It would fire up and run great for another 15........ I've tried everything I can think of and the problem persists. It is still running rich and the carb has a non-adjustable main jet... sometimes when it dies out, one of the spark plugs is wet.
What I've tried/ checked:
rebuilt carb (float level is correct)
new air filter (also oil and filter... not that it should effect this)
plugs, wires, cap and rotor (has been converted to a pertronix so no points/ condensor)
new coil
fuel lines wrapped with insulation (vapor lock???)
New fuel pump and lines
fuel pickup is clean
gas cap vent is working fine
exhaust checked for blockage
jumper wire run straight from battery+ to coil+ (to eliminate a possible bad oil pressure switch)
compression is good
I'm sure there are other things I'm forgetting....
Anyone have any ideas for me????
Background:
new coil
compression is good
). It either has to be the fuel pickup, or the pump so it shouldn't be too hard to figure out! My best guess would be pump as there isn't a cloud of extreme rich exhaust anymore when I'm running it. I ran out of time, so I haven't pulled plugs to see for sure that it is leaned out.
