Hit my name is Scott just got my self in to a 6x6 amphicat a few days ago looking for some other people in co that might be able to help me figure a few thing out on it and go riding with any one out there pm me
Thanks well I fixed alot if it having some pronouns trying to turn it and I do am trying to track down what year it is as well the year size and kind of engine do you live in co if so where around im in arvada
No i live in Michigan. An what trans us it it the brake style or the T10? Should have a sachs engine unless it's been changed either a sachs sa280 or sa290 an there is a couple different ones depends on the trans you have
Ok that's the teams set up that I don't like it doesnt turn very well. There is a manuel on the website for. Those clutches need adjusted with a feeler gage to 1/16. Even after I did all the adjustments it still doesn't turn like a t10 the t10 is close to a t20 it will turn on a dime. Just keep checking an making adjustments. Also spray those brake disc with brake cleaner. I also found it to turn better when I gave it a lot of throttle.
You have to have the frame an everything from the t10 setup it's all different. Even drives from the over side. You should be able to find one cheap. I have less than 400 in both of mine. Just keep checking craigslist an the site here
ya i havent been able to get it out on to the dirt just yet tried it on the street the little bit of dirt i did get it in it seemed to try and turn better then on the street. im getting the trans axel to disengage now but im thinking that the brake pads are to worn down i cant find an ajustmint on them to try and move them in closer not having any luck finding any new ones eather and i have a really bad leek on the front part of the tran need to track down and fix if i can find a gasket set for it
