Service time... yuck... I always dreaded the messy fluid change. It always seemed that no matter how much care I took to prevent it I wound up with one oil or the other or both in the floor before I finished. I've read in several posts about others having the same problem and I know I am not alone in the experience. Reading in the trackster service manual, the way to go about changing the fluid in it's transmission is to drive the rt track onto something so that side is about 18" higher than the left. Then pull the lowest mount bolt, then the temp sender and let all 7 qts flow out into my tub, and out the 3/8" hole where I pulled the bolt. Well... that's fine except that the sender hole is about twice the diameter of the bolt hole, which means oil everywhere..
So here is an idea:
#1 using a 5 gal bucket with a sealing lid, cut a hole big enough that my shop vac hose will fit snugly in.
#2 drill a second hole for a 1" suction hose to fit snugly in. A smaller hole for venting may be needed, mine is a big vac and the 1" hose will create too much restriction
#3 push the suction hose far enough into the bucket to keep oil out of the shop vac hose.
#4 attach hoses, turn on vac and suck up oil without getting it into the shop vac hose. (they are a pain to clean oil and dirt out of) Oil goes in bucket leaving my shop vac clean. Remove lid and pour oil into storage container.
What do you guys think about that?
So here is an idea:
