Some wont start, mine wont stop!  I am correcting a list of things wrong with my just purchased 93 Argo.  Not sure how the factory kill switch was originally on the 16hp vanguard, but on this one there were two separate toggle switches that individually grounded each coil to stop the engine. One switch still works and stops one cylinder but the other switch is not killing the other coil, replaced the switch and same thing. The only way to shut it totally down is to pull of the one cylinders plug wire.  Seems like the red wire leading to that coil has opened up somewhere inside the housing.
Is this a problem you guys have seen before? How was the factory kill switch set up?
, i got the same problem on my 18hp brigg, and the reason for the second cylinder not shutting off is that in the wire is a diode( i hope this is the same name in english as in french) and this diode is busted. When it's busted it will NOT conduct at all and by the way not shut down your engine.
   if it don't float with out you getting wet .  don't bring it !
    R.I.P  sage rogers   4 11 09  .
