Ok guys looks like gonna have to use this jlo for a bit till I can get another motor.....was gonna try to fire it up but don't even know where to start.....was gonna see if y'all could help me get a electric start wired up and see what we got from tere.....any advice.....I know nothing about motors
Jlo Rockwell wiring help
Find one for a lawn mower. It's pretty much standard that they have one terminal that grounds out the motor when turned off. It's also helpful to have one that has a + terminal whenever the ignition is on, headlight or run position. This allows for an hourmeter to be hooked up, and helps with the maintenance schedule. The other option is to buy a tach/hourmeter that hooks to the spark plug wire, and counts time whenever the motor runs.
Originally posted by Irvan105 View PostOk so ground the black wire and the two yellow wires go into ignition?
The black wire gets grounded to STOP the motor from producing a spark and kill the engine. It needs to be open (not connected to anything) when the engine is running.
I assume you mean the Ignition switch. It gets:
B+ (positive from the battery to run accessories)
+ to the lights (first key position past "off")
The black wire from the motor(Ign kill)
The ground, from frame or battery usually to the metal shell of the switch, but could be just to a terminal. This will connect to the blk from the motor ONLY WHEN the key is turned off.
Some switches will also have a terminal for battery to accessories when in "lights" or "run" positions. Accessories like the hourmeter, electric fuel pump, etc.
your motor will run with no wiring connections. To stop it, hook the black wire from the motor to the toggle, and one from the battery- or frame to the other side of the toggle. Now label the switch "engine kill". When you turn the switch on, it will kill the motor. To restart, just turn the switch off, and enjoy the exercise of the pull start
I don't get the purpose of the 3 position switch.
The original rectifier looked like this New Bosch Rectifier 8A Fuse for Snowmobile Vintage 0212 910 001 G 12 65 JLO | eBay
