I know this is not the forum for this but i know this motor was used in some six wheelers the engine is on a cub cadet i bought it for 225 the engine will make a chirping sound when u rev up from idle but goes away i really cant feel a miss or anything could it be a leaking head gasket that what i keep reading on the internet what i can find on this motor its firing on both cylinders but since coil is used for both sides if i pull the left if sittin on tractor plug cap it dies but does same if i pull off right so i cant tell if its firing right or not also the govner doesnt move that much is it suppise to move a good bit or not when throttled up u cant see it move at all but motor does increase in speed im not much for these type of engines such the simplest thing can set one off running from good to bad at the flip of a switch
kohler m18 18 hp engine chirping
you can download the service manual from the kohler website for the m18 it has a trouble shooting section. A chirping sound is very vague problem. Is it loosing power? the governor doesn't move that much, it adjusts the fuel intake when the motor goes under a load. do the sparkplugs look good? Have you've given it a tuneup lately?(new sparkplugs, aircleaner, fuel filter, oil change, fresh gas).Last edited by newargoowner; 11-22-2012, 07:00 PM.
No power loss even moving with deck on it makes the chirping noise when u rev it up till it reaches the point u want then goes away i have read a leaking head gasket will do this its not that a gasket is that much just dont want to tear something down that needs not be
my nerves get very thin trying to work on these engines u have it or u dont
