Hello
I have just installed a rebuilt 399 Kohler 2T into my 1986 Argo
I was hoping someone may be able to help me with the electrical wiring coming from my stator.
I have just installed the new rectifier and just trying to run the wiring that comes from the stator plate to the correct locations.
I have two yellow leads and two black leads. I am sure that the two yellow leads are to run to the two #51 connectors on the rectifier ....and then from the #53 connectors on the rectifier, one will go to the light switch and one to the starting solenoid.My system is 75 watts and has a separate light switch.
I am not sure how to run the two black leads...i think they are for the engine shut off...but i am not too sure where to connect them.
The schematic shows two leads coming from each ignition coil connecting to the starter switch....but my black leads are coming from the stator. I was thinking that those 2 black leads should connect to the ignition coils also and the from the ignition coils to the starter key switch.
I was hoping that maybe someone would be able to help me with a diagram or explain the wiring set up for me or let me know if i am close to the correct setup.
Thanks
Barry
Thanks
Barry
