Hi Folks,
I would like to draw on some of the experience in the forum. I have a transplated 23 hp briggs in my 6x6 and am having a hell of a time getting the idle down. Always have had problems with these engines wanting to idle low. When i say low, 900 rpm is where i would like it to be. Below 1100 - 1000ish the engine governor will always want to open the throttle. I can hold back on the butteryfly lever to rest on the idle screw and she purrs away, let go and she pops back up to 1000 - 1100.
Here are some of the things i have investigated..
Does engine idle low without governor attached? yes, very smooth
Correct springs? Yes, ordered from ODG dealer, colors verified
Intake leaks? Checked, none. and the engine idles nicely without governor
Linkages in good shape? yes, little wear and no obstruction
Fuel mixture? I can set a little rich to get the idle down a little more at the cost of fouling plugs, actually this resolves the small bog issue off idle...Any amount of idling time and the plugs foul
My gears have never grinded and and i dont mind setting the idle a little higher then its supposed to be.
Any thoughts or comment would be appreciated.
Thanks
Thanks
