So after many heat issues and lots of tinkering I have 1 for sure and possibly another bad 16hp engine. Carroll Stream did not want to do anything to correct the issue. I would not recommend these engines to anyone. Heat seems to be from the lower end crank is rainbowed from heat. Purchased a Predator from HF to try now. Had great luck with them on mini bikes.
Carrol Stream Engines
Originally posted by Toys4Me View PostSo after many heat issues and lots of tinkering I have 1 for sure and possibly another bad 16hp engine. Carrol Stream did not want to do anything to correct the issue. I would not recommend these engines to anyone. Heat seems to be from the lower end crank is rainbowed from heat. Purchased a Predator from HF to try now. Had great luck with them on mini bikes.
Put some video on you-tube and make sure you name the product that came from Carrol Stream, I bet that will spur some customer service.
