I have a 1989 max ii with oh160 engine. In November I picked it up in Minnesota and drove the 12 hours home. When I picked it up we checked for spark and it was fine. After getting home I changed the fluids, new throttle and choke cable, removed and cleaned fuel tank, new fuel lines, filter and primer bulb, new spark plug and battery.
It had been sitting for a while (inside barn)so I am planning on tearing apart and rebuilding the carb.
The problem now is I am getting no spark. In addition after cranking light smoke is coming from the neg battery post.
I have been tightening up all electrical connections but still smoke and no spark(smoke comes after only 5 or so seconds after first cranking attempt)The only noticeable thing I see is the positive battery cable on both ends where the ring connectors are clamped is pulled away so you can see a little of the wire that should be covered by the insulation. I am not sure if this is the culprit but going to pick a new cable up this afternoon.
I am planning on putting a new engine in but....twins
on the way so that will have to wait. when we found out I told my wife now I needed a Max IV which didn't go over to well! Need to get this one going so she will see how fun it is and let me buy MORE
Any ideas?
Thanks
Brad
Any ideas?
Thanks
Brad
