No pulled needed. Use a big strap wrench and crescent wrench to loosen the big bolt. When you have loosened the bolt, beat on it with a hammer. I use a 2 1/2 lb hammer for this. The fly wheel will then come loose. Remove the bolt and just take the fly wheel off by hand.
Siezed Briggs 16hp Vanguard... buy new or rebuild?
If your engine is newer and there isn't any corrosion on the shaft or the flywheel you can do what Drew suggested and it'll work well. If your flywheel hasn't been off in a long time or there's some corrosion on it, you'll need a puller. Use a steering wheel puller. You can get one from Autozone with their free loan a tool service. All the correct hardware should be in the kit.
Steering Wheel Puller | AutoZone.com"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
I dropped a screw driver tip in there engine running. shut it down and locked it up. got the flywheel off with puller, pretty easy. don't rotate the flywheel to much though as you can damage the magnets. after cleaning the dirt and magnet debris I only had minor damage to two magnets but be prepared to get a new stator. I had more damage to it and replaced it. I'm no mechanic and I got it all resolved. I didn't do anything to the flywheel but clean it and re install. I still get 13.5 volts on the meter. I looked high and low for a new flywheel though and mine was dicontinued and many places listed it in stock but seemed everyones invertory listed as wrong. I did get one later for pretty cheap but haven't needed it so far.
I just pulled the old 16hp from my 6x6 and have to pull flywheel to change stator. In the process of doing something else I broke one ear off the flywheel...that is when I called it a night and put my hammer down gently and walked away. Good thing I have an extra flywheel...just have to get the patients to go back at it and try and get the old one off now....
Still debating on if I should swap it out for the 16hpe duromax???????Even if you’re on the right track, you’ll get run over if you just sit there.
—Will Rogers
Originally posted by amphibious drew View PostI think racerone3 said he has a flywheel. He is a good guy and trusted forum member. I would check with him
photo attachment is what I have for you EdAttached FilesLast edited by racerone3; 01-24-2013, 09:29 PM.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
