Ok I got a 1987 argo 8x8 that I took in a river and ended up getting water in the air intake what's the easiest way to change the oil and transmisson fluid its got a kohler 18hp magnum engine any help is greatly appreciated thanks
Changing Fluids in Argo Engine
Thank you for the reply, I will make an oil trap just like that. I believe the oil drain plug is pretty low on the engine is there any way to get to it? And I don't even see where to put transmission fluid.. I'm new to the argo. Also is there anything else I should do because it sucked in water? Thanks again
The m18 oil drain plug is on the left side of the machine(allen head). when i change it i jackup the right side a little higher than the left since the plug is not on the bottom. I also warm the motor up first. i use a cut to fit 1gallon washer fluid bottle. The transmisson drain plug is on the lower backside. the fill hole is plugged by the breather/dipstick which sits on top of the transmisson. gentle unscrew it from the transmisson. i think its made of brass. i had to soak it with pb blaster and carefully unscrew it. the transimisson uses .8 qt of 80/90 hyoc gear oil.Last edited by newargoowner; 02-14-2013, 12:33 PM.
I need one of those for my OB's and SeadooOriginally posted by JohnF View PostI use a Pela 6000 oil extractor and suck the oil up the dipstick tube. I got it because I added a skid plate to my Jetta TDI that made oil changes a real pain. It is really awesome when I change the oil on my 4-stroke outboard.
I use an extractor as well...in fact I have both the Princess Auto Pneumatic/manual models and they work great for all kinds of fluid extraction. The fact you can hook them up to your air compressor freeing up a hand really helps when trying to extract from small hoses or drain holes.
For those in canada Princess Auto has the 6 Litre one on sale next week for $89 vs regular price of $109.99
Thank you all for the replies so just to be clear I sunk the engine air intake and sucked in water, I have to change engine oil, change transmission oil( I read that the 1987 kohler 18hp magnum can use motor oil in place of transmission fluid is this true?) And drain the fuel bowl? Then try and start it up? I don't want to try and start it with water still in engine is there a drain plug for the engine other than motor oil? I sorry I don't know much I just got this argo a few days ago.
So, just what exactly did you do? Not being nosy......... well, ya, I'm being nosy, lol.
Did you just get a little water in it? Did you Hydraulic Lock the motor? Did you sink the machine? Why do you think there is water in the Trans?
Does the engine turn over now? Did you pull your Spark Plugs?
If your oil is not "milky" looking on the dipstick, you are probably OK. If it was just a burp of water, you can probably get away with just adding Gas Line Antifreeze (Isoprople Alchohol)to your fuel to absorbe the water in the carb (Should add a bit when you fuel up anyway)
As long as the Trans was not UNDER water it should be fine, again, you can check the dipstick for water contamination. As far as I know, you can NOT use engine oil in the trans, 80/90 Gear Oil is what you want (unless you are on a remote trail, and just need to get home, in that case I would use engine oil if its all all I had)
Sorry for all the questions, just trying to "see" what you did.
Ok I went into a shallow river around and got pinned against ice and while trying to get out of the river water got into the large intake ontop the engine enough to start making the engine sputter... I shut it off as soon as I new water was in the engine but I might have been to late it started to lose power before I turned the key. But at no point did the entire engine go under water or I. Completely sink the argo. I'm not a mechanic but I'm a quick learner and I m familiar with atv engines and general maintence on trucks i just don't want to ruin the engine
Pull the plugs, crank her over, if no water sprays out the SP hole, drip a little 2 stroke oil in the cylinders, put the plugs back in, drain the Carb Float Bowl and fire it up. Let it run for a minute, shut it down and check your engine Dipstick for water.......... I doubt you will see any. Fire it up again and go have fun.Originally posted by xusarmy View PostOk I went into a shallow river around and got pinned against ice and while trying to get out of the river water got into the large intake ontop the engine enough to start making the engine sputter... I shut it off as soon as I new water was in the engine but I might have been to late it started to lose power before I turned the key. But at no point did the entire engine go under water or I. Completely sink the argo. I'm not a mechanic but I'm a quick learner and I m familiar with atv engines and general maintence on trucks i just don't want to ruin the engine
