Changing Fluids in Argo Engine
maybe it sucked up some trash and has the main jet restricked, i would make sure you have spark on both spark plugs if so pull carb and clean. its a simple carb to pull and clean
Anything to help troubleshoot this or just condesending comments towards someone trying to figure this out? I'm no mechanic but ill learn as I go with good advice and a little help thanks
That's a good way to blow the heads clean off it...Originally posted by xusarmyMaybe use some starter fluid to get it running and try and keep it running until it gets hot and burns off left over water? Sorry for multiple posts I'm thinking
Thanks a lot every one ill get started and let you know how it goes
I have the panels off and have access to the oil plug what size allen wrench is needed the largest I have 1/4 and its to small
Well I've made progress I changed the oil and started it up and it ran for about 2 minutes then died and won't start. I didn't do anything with the carb but I know its getting fuel any ideas
Also a little water came out exhaust, I have the tranny draining but its coming slowly.. should I take off the carb and empty it?
Maybe use some starter fluid to get it running and try and keep it running until it gets hot and burns off left over water? Sorry for multiple posts I'm thinkingLast edited by Mike; 02-15-2013, 06:59 PM. Reason: merged five consecutive posts. You can edit your original thread instead of posting multiple times in a row
Hey man, I saw your question in the other thread and see you are getting answers here so I'll leave that other thread to it's own question.
I don't know your engine specifically, but yes, I suck the oil up the dipstick tube. The extractor tube is either (I have both) a flexible metal rubber coated tube or a stiff plastic tube. Where are you located? If near me I would lend it to you but based on your description of having ice in a river I know you are nowhere near me.
Some carburetors have a drain which would make this easy. One of the tractors I used to deal with did not so I would remove the carburetor and hold it upside down and let everything drain through the vent holes. Do what newargoowner says and download the service manual - you ask enough questions and poke around in there enough that you will use it and someday be one of our M18 experts!
There we go! I would take the belt off - it's easy - it would get it out of the way. newargoowner didn't mention it so I thought I would.Originally posted by newargoowner View Postif you take out the drivers floorboard, then the firewall (4 bolts) then you can to the oil plug from underneath the clutch system(belt). it will open up alot of room. this is how i do it.
Well I think I found the bolt to drain the oil but I can just barely squeeze my arm in there its the lowest bolt on the right side of the engine are the pumps you guys using just a rubber tube you stick in the dipstick hole to suck out?
The oil drain plug uses an allen wrench. when sitting in the machine, it is located on the lower left hand side of the motor, below the primary motor clutch. They are talking about the float bowl on the carb. you will have to take the carb off the engine to take the float bowl off. if you go to the kohlers website (kohlerengines.com/), you can download the service manual for the M18. it will show you everything about engine.
I've tried two different bolts I thought were oil drain plugs but no oil came out? Where is the oil drain plug at? also where is the drain on the bowl ? I don't see and screws low on the bowl ?thanks again guys
john I pulled the plugs and turned the key and no water came out but the oil is milky so I'm trying to find the oil drain plug or bolt but none of the 10mm bolts I pulled let any oil out..
I suggested draining the bowl because if water got in the bowl vent then you will have to work it out of the carburetor and through the engine before the engine would start - and that can take FOREVER and a battery or two. To be honest, I would probably hit the starter first to see how lazy I could be. Okay, and maybe a shot or two of starter fluid with fingers crossed. I second the fuel drying additive.
Hey, I'm gonna start a thread here.
Ingesting Water
in this thread [Changing Fluids in Argo Engine] xusarmy has a situation in which his Argo takes on water through the intake.
So what do folks think about this approach to xusarmy's situation:
I think that if a little water got into the intake I would have either opened the throttle and/or choked it a little (to enrichen) to hopefully work the water through. Good idea?
If you say shut it down immediately: As a pilot I am aware that there are circumstances where a choice is made to save the airplane or save the souls, Does circumstance make your answer situational?
<At one point I had a bit of discussion differentiating diesel/gasoline/racing engines but after writing the above question became aware that this is just another"situation".>Last edited by Mike; 02-15-2013, 06:56 PM. Reason: merged two threads on the same topic. No need to discuss the same thing in two locations
there wasn't one on my 87 8x8. but i added one when i rebuilt it. if there is one it would be on the front lower leftside of the motor sitting in the machine. i bought standard oil filter adapter for the m18, so i had to trim some sheet metal. u can also a buy a remote oil filter system for it, but it is more costly.
Rock doctor, thank you very much ill try first thing in the am and let you know how it goes
Pull the plugs, crank her over, if no water sprays out the SP hole, drip a little 2 stroke oil in the cylinders, put the plugs back in, drain the Carb Float Bowl and fire it up. Let it run for a minute, shut it down and check your engine Dipstick for water.......... I doubt you will see any. Fire it up again and go have fun.Originally posted by xusarmy View PostOk I went into a shallow river around and got pinned against ice and while trying to get out of the river water got into the large intake ontop the engine enough to start making the engine sputter... I shut it off as soon as I new water was in the engine but I might have been to late it started to lose power before I turned the key. But at no point did the entire engine go under water or I. Completely sink the argo. I'm not a mechanic but I'm a quick learner and I m familiar with atv engines and general maintence on trucks i just don't want to ruin the engine
