Ok could use a little help on this guys....
I have been working on my 2004 bigfoot this winter changing chains, doing body work, and engine maintenance. Argo was running fine a few months ago before I drained gas out of it. Been sitting outside (covered) in very cold temps with battery maintainer on it.
Changed fuel filter, plugs, battery, throttle cable, oil, and installed new winch, bilge, accessory plug and digital battery meter tapping into existing electrical. All electrical devices work fine now.
Fresh gas in the tank, engine turns over but doesn't start or sound like it's getting spark. Tried started fluid but no effect. Checked spark and either not getting spark or getting weak orange spark in tester. Put old plugs in and no difference. New battery looks fully charged.
Also noticed new fuel filter (installed correctly) is hardly filling up with any gas. Ensured gas line was not pinched and gas was getting to filter. Pulled line off pump that goes to carb and tried starter and fuel squirts out but filter still seems to have barely any fuel in it. Took filter out and connected lines together and tried it but no go.
Checked ground wire to engine with multimeter and getting good ground. Also checked gas tank vent line and it is unobstructed.
So seems to me I have both a fuel delivery and electrical (spark) issue. Will change fuel line and pump tonight and clean out carb but doubt that's my issue. I'm stumped as it was running so well before I drained fuel and added various electrical accessories.
Any suggestions would be greatly appreciated....
