Hi Guys
I purchased a fairly low hour 2007 Frontier Lite with 18HP Vanguard recently knowing that it had carb issues for sitting for awhile. I have replaced the fuel lines, fuel filter, siphoned most of the gas tank out, new plugs and engine oil. After i cleaned the carb out it would run on half choke for 3-4 minutes and eventually die. I did this numerous times and didn't hear any odd noises besides the engine sputtering once in a while.
Today i noticed that one of the valve covers never got warm after running so i disconnected the spark plug wire. The engine kept running the same way which was a surprise to me. I then took off the valve cover for the front most cylinder and there was a bent push rod sitting there that i could take out. The other one looks ok.
My questions is what damage do you think occurred as it ran like this for some time and should i consider a new engine, possible upgrade? Has anyone had something fixed like this before and how much did it cost? I am worried that if i take it into a briggs mechanic next week the bill will be close to a new engine...
Your thoughts?
Thanks and great website!
Your thoughts?
