carborator fuel shut-off solenoid
  • carborator fuel shut-off solenoid
    Hey guys. Can I pick your brains? I'm currently troubleshooting a possible carborator issue on my 04 avenger. I'm tying to rule out a fuel shut-off solenoid malfunction. Although the solenoid works fine on bench testing, is it possible for it to malfunction after continuous load? (i.e. after the machine has been running for 10 or 15 minutes).
    Thanks
    Last edited by Mike; 03-17-2013, 01:58 PM. Reason: moved thread from Argo forum to engine forum
    Probably not.
    Unless the electrical connection is bad on the solenoid.
    What is your issue.....running rough,no power or stalling?
    More likley the fuel filter or fuel pump.
    Some members have mods for the solenoid to eliminate it .
      I have a 14hp Briggs on a brushhog I built that had one of those aggravating contraptions on it. They only serve as a fuel shut off when you aren't running the engine and yes it would malfunction after running for a while, hit a few good bumps and the thing would go dead. I was able to find one of the old style plugs that held the bowl on that had the same thread, I put it in added a fuel shutoff and it solved the problem.
        yah i hate them things..ive got a few things with them on it...typically...i remove them, use a big pair of Cutters or a grinder, and remove the plunger on the end of it..lol Then screw em in and plug the hole! Tadah! Done! bahahaha.
