Hi All
I have a 2000 Bigfoot with 18 HP Vanguard Engine (260 hrs). I just changed the fuel filter, but I don't know if previous owner ever serviced the carb. I have it out two times now with the same problem occurring. It won't start cold without first priming through the carb (a real pain). The choke does not seem to have any affect. After running for about an hour (idling most of the time), the gas gives out. The engine won't accelerate even in neutral. It will still idle but barely, and then just quits. I was out in the snow a mile from the trailer, and the only way I could get back was to prime through the carb all the way. It seems however if I wait a while (30 minutes) it will start and run OK. I did crack the gas cap open and heard a whoosh of air (in or out not sure) when I got home. Is this my problem or should I be looking at something else? Thanks for all your replies. Desperate
