84 Kohler 17 hp no spark!
  • 84 Kohler 17 hp no spark!
    I have no spark in either cylinders.This is the first time this argo wouldn't start.Anyone know what might be the problem? Coil?i cheeked the little fuses they seem fine.there are two little parts off of the coil ? any help would be great thanks :-)) Also if its the coil what type of coil should I get? thanks :-))turns over ok as well.how do you check or test the coil as well if that's the problem? Cheers!
    Last edited by Mike; 03-30-2013, 12:30 PM. Reason: moved thread from Argo forum to engine forum
    Check your points, there is a link to a manual down this forum in a post called electrical output early 80's 8x8. Or near to that from feb..
      "there are two little parts off of the coil ?"
      What do you mean by that?
      Did the engine sit for a long time or was it running and just stall?
      Is it a 2 stroke with coils mounted on the outside?
      Its unlikely that both coils would fail at the same time
      Did you hear any backfire when it was running?
      Could be a bad ignition switch or corroded points.
        84 koehler 17 hp Condensor?
        anyone know what type of condenser I need for an 84 17hp Koehler. I believe that's why I have no spark to my plugs because I did a test on it and read nothing so I believe this is my problem and need to replace it.Thanks kindly for any help on this Cheers :-))
        Last edited by Mike; 03-31-2013, 10:35 PM. Reason: moved thread from Argo forum to Engine forum and merged it with the existing thread on the same topic
          it has one coil with two out puts 17 hp twin kohler and condenser and points off coil
            where or what type of condenser do I need?
              Try mfgsupply.com. I usually have some good luck with them and fast shipping.
              Search results for: 'kohler' | MFG Supply
                If you can give us the model # of your kohler 17 hp engine it would help.
                The service manuals are here : Kohler Engines: Owners and Service Manuals: Manuals and Maintenance
                The coil on the kt model has a + terminal on the coil from the keyswitch.
                Test for 12v there when the key is in the run position .
                Other models have different ignition systems so we really need to know the model # you have.
                  model is KT17
                    also I was wrong its a 1983 kohler kt17 hp
                      Ok heres your manual
                      Did you test if you have power at the + on the coil when the keyswitch is in run position?
                      Pg 32 and 33 explains how to test if your coil is good.
                      Pg 31 explains how to check the condenser.
