After driving for awhile, when I shut it off the engine backfires? Any ideas on what to do or what is causing it?
Briggs 18hp backfires on shutoff???
the dash sticker on the newer MAX with carb solonid fuel shut off say to raise engine speed to half throttle before shut down. This makes the engine roll over after shutdown with no fuel and clears the mixture from the hot muffler.This really helps on ones with fuel shut off,not with standard carb.
There's nothing wrong with your engine. This is just the nature of Briggs and Stratton Vanguards. You won't really need to adjust anything, it's just how they act. Very often on rides you'll hear a "pop" which is a backfire from one of the 6 wheelers when we all shut our engines off to stop somewhere. That backfire is always followed by someone yelling, "Briggs!".
I did adjust the idle speed up a bit, as it was idling to slow. Now I get more backfiring on shutoff. I'm going to adjust it back a little again. I've got to find some sort of solution to the backfire. I will be using the Max to deer hunt and I can see it now, I drive to my hunting spot and when I shut it off every deer in the area takes off due to the shotgun backfire I get. I mean this is a real, real loud backfire. But, you are right, I have a briggs on my Zero turn mower and it does the same thing. I'm gonna keep researching to see if I can minimize the backfire."I'm NOT stuck, I'm just temporarily stopped"
