I have a 1996 Max IV with an 18 HP OHV Vanguard. Recently the engine knocked a round hold in the back side of the block/ cast casing.
I saw several posts on engines but couldn't find if there are other things I need to consider when purchasing a replacement engine.
How hard would it be to replace the block / main casing vs buying a new engine? Is it worth the time / trouble considering it is already an old engine?
If I go to a 23 HP Briggs, is there a certain one you all recommend? Are there horizontal shaft engines that will not work even though they have the correct shaft? I saw this one for sale on eBay for $600 but didn't know if this mower engine would bolt up correctly with the correct height making the belt tension right.
BRIGGS & STRATTON 25HP OHV V-TWIN RIDING MOWER ENGINE NEW WITH BRIGGS WARRANTY
I understand I need a 1" keyed shaft, are there a lot of differences on the height from the base of the casing to the shaft that would impact belt distance? Am I going to need to build a spacer / bracket if I go with something other than the original?
Sorry for so many questions, just ready to get it running again and not sure what all I will need to consider when buying a new motor that isn't directly from RI.
Thanks in advance for any / all help! It will be greatly appreciated!
